Field Editing Mode
1 year 3 months ago #11648 by akshehu
Field Editing Mode was created by akshehu
Hello.
Please i have made some feilds in my from to be non editable. However, i suppose if the field is not editable the filled data (field) should be grey (See image) currently when i go to edit from, the fields are not editable but it remain same as a normal field. How can i make none editable field highlight in grey?
I use latest Joomla 5, Helix ultimate template-latest, i chose Bootstrap 5 in the from layout configuration.
Thank you.
1 year 2 months ago #11658 by akshehu
Replied by akshehu on topic Field Editing Mode
I found a way through some Css coding to the template and it worked.
Thank you.
1 year 2 months ago #11662 by Administrator IV
Replied by Administrator IV on topic Field Editing Mode
Hello akshehu,
Thanks for your solution.
The template is always the first place to adjust CSS.
Visform's unique passive integration strategy:
docs.joomla-5.visforms.vi-solutions.de/e...ucture/introduction/
If you want to extend Visforms with your own CSS, that's also possible.
Frontend web assets:
docs.joomla-5.visforms.vi-solutions.de/e...-frontend-webassets/
All settings are made in the form:
docs.joomla-5.visforms.vi-solutions.de/e...are-made-in-the-form
Kind regards, Ingmar
1 year 2 months ago #11663 by Administrator IV
Hallo akshehu,
We consider this a bug in Visforms and will adjust the behavior.
I created a development issue in the bug list:
Issue [VF-1501] Forum: Read only fields: Color coding is missing
There may also be a file-based hot fix for this bug in the very short term.
