Integration issues with another Plugin
11 months 3 weeks ago #11790 by akshehu
Hi..
I am running lates joomla 5 and latest visform+subsription extension.
I am developing a plugin that pull data from the visform field, however, when i use the events in the php files and other files, Old submitted forms and mapped and pulled from visform to my new plugin. BUT when i make new submission from the front end as normal user, visform stores it in joomla backend as well as SQL database, ut it will not record in my plugin as submitted. since it is not submitting to the database, it is not adding up to my new plugin forms which pulls the field data from visform.
What could be the main issue.
 read you documentation but something isnt right.
can you help?
I am on localhost and not live.
Thank you
11 months 3 weeks ago #11798 by Administrator AV
Replied by Administrator AV on topic Integration issues with another Plugin
Hi akshehu,
please always name the acuall versions, not 'latest'.
This post might be read sometimes in the future, where nobody knows what the latest version was, at the time, when the post was written.
Which events do you use?
What are their names?
11 months 1 week ago #11834 by akshehu
Replied by akshehu on topic Integration issues with another Plugin
Ok i will take note of this in future.
I already solved the issue.
Thank you.
