initListRB : Problem to retreive values
12 years 6 months ago #438 by netface
Hi
I just upgraded Visforms from 1.0 to 2.0.1 and if I try to add a field or to edit an existing field in the form (created with the 1.0 version) I receive the error in the object (initListRB : Problem to retreive values - null : null), two times. Then I can't save the modifications.
The form still works but it seems impossibile to update or modify it.
Thank you,
Andrea
12 years 6 months ago #440 by Administrator AV
Replied by Administrator AV on topic initListRB : Problem to retreive values
Hi Andrea,
thanks for that information.
Sadly I'm not able to reproduce the problem. I think there is one special field configuration in your data which I have not thought of during my testings and which causes the problem.
Do you have a backup of the visforms and visfields tables from before the update, which I could use to explore the problem?
Can I get a backup of the visforms and visfields tables after the update as well or just that one, if you haven't any backup from before the update?
You can send them to my contact e-mail (see below the forum).
Thanks for your help!
Kind Regards,
12 years 6 months ago #442 by netface
Replied by netface on topic initListRB : Problem to retreive values
Sorry, no backup :oops:
I'm going to send you the visforms and visfields tables after the update, to your contact e-mail.
Andrea
12 years 6 months ago #443 by netface
Thanks to the very kind support of Aicha we found out that the problem was the browser's cache: it continued using an old js file from the previous version, that caused the error.
Emptying the browser's cache was the solution.
Andrea
