Visforms joomla 323 not working properly
12 years 5 months ago #483 by Rankman
Hello,
i use the newest version of Visforms and made a form.
Everythings well but the information of de data of an filled in form is not stored in the database and the user and the administrator don't get en email with the results.
Any suggestions
regards,
Rankman
12 years 5 months ago #484 by Administrator AV
Replied by Administrator AV on topic Visforms joomla 323 not working properly
Hi Rankman,
these features are controlled by parameters. Did you set up the form correctly?
Form -> Tab Result -> Save result (to yes)
Form -> Tab Mail Options (according to your requirements)
Can you please send me a link to the form, please?
12 years 5 months ago #490 by Rankman
Replied by Rankman on topic Visforms joomla 323 not working properly
Yes the settings are correct. I've settup a test version at home and this one works perfectly.
Can it be a php version thing?
12 years 5 months ago #492 by Administrator AV
Hi Rankman,
Visforms is compatible with php 5.3.1 + and recommended php 5.4. + (same as Joomla 3). So, if it were a php version problem there would be a problem with your Joomla! installation as well. Which version is running on the server?
If the settings are correct, as you claim, the problem you describe indicates a fundemental problem (so your idea about the php version problem was the right direction). But I need a link to the form, that is not working, to look into which fundamental problem it might be.
