Listbox or radio button data not emailing properly
12 years 4 months ago #540 by whouse
When I create a list box or radio buttons, the data for the value is all that is saved in the data or sent in the email. The label selection is not included. Probably something I did wrong but I was hoping you could help.
Thanks!
12 years 4 months ago #541 by whouse
Nevermind. I figured it out. The value is what is saved and the label is what is displayed on the form. Makes sense after I thought about it a little while. This is the same for list boxes as well as radio buttons and I'm sure checkboxes also.
Thanks for the wonderful component. Best form component out there!
12 years 4 months ago #542 by Administrator AV
Replied by Administrator AV on topic Listbox or radio button data not emailing properly
Hi whouse,
I've decided to reduce my work time on weekends and therefore didn't see your post first from sunday til now. I would have answered you today.
I'm glad you figured it by yourself.
Kind Regards,
12 years 4 months ago #543 by whouse
I can't blame you for not working weekends! Hope you had a good one.
I had enough time to figure how dumb I was and worked through it. :)
Again, thank you for a wonderful component!
