Fields validation
12 years 3 months ago #605 by xomi
Fields validation was created by xomi
Hi, I'm trying this component and I find it very useful and nice to use.
But I'd need to validate some fields (as spanish id card or bank account) that have hash digits, and I don't know where are the best place and way to do it. I'd like to do it as an override or plugin of the component, avoiding conflicts when updating the component.
Did you think on any solution to this?
Thanks a lot.
12 years 3 months ago #606 by Administrator AV
Replied by Administrator AV on topic Fields validation
Hi Xomi,
can I conclude from your statement that you want to do it as an override or plugin, that you have JavaScript development skills?
12 years 3 months ago #608 by xomi
Replied by xomi on topic Fields validation
Yes, I have both JavaScript and PHP development skills.
12 years 3 months ago #610 by Administrator AV
Hi xomi,
Visforms uses the jQuery validator plugin.
Plugin is using standard jQuery plugin development methods and is extendable.
You can use the addMethod function to add custom validation. Documentation is on jqueryvalidation.org/jQuery.validator.addMethod/
You can use the code in componentes/com_visforms/views/visforms/default.php at about line 230 as example. I already included a custom date validation there.
I think this gives you enough options to keep you custom validation code seperate from the Visforms code.
The following user(s) said Thank You: xomi
