form does not work
11 years 10 months ago #964 by imkejoemrati
form does not work was created by imkejoemrati
hi installed visforms 3.1.1 on a website. i made a few forms, non of them work. On the website, i cannot fill in any text field. de date fiels, does not display a calender,
can you take a look at bzvsuriname.com/web/index.php/2014-10-27...ce/individueel-gezin
Please help
Regards
11 years 10 months ago #965 by Administrator AV
Replied by Administrator AV on topic form does not work
I will look into that tomorrow.
11 years 10 months ago #969 by Administrator AV
the default.css of your template sets the font color of elements with class inputbox to #ffffff. (line 124)
As Visforms uses this class for inputs, sets the background-color to white and does not set a text-color of its own background and font color are both white with your template.
Therefor you cannot see what you type into the inputs but actually it is there.
The following user(s) said Thank You: imkejoemrati
11 years 10 months ago #982 by imkejoemrati
Replied by imkejoemrati on topic form does not work
thank you very much for the quick response. It works!
One last question.The colors of the labels are light blue, where can i change that?
11 years 10 months ago #983 by Administrator AV
every modern browser has built-in developer tools which you can use to find out which css rule in which css file is used to style a html element.
Looking into the individual configuration of your website is far more than you would usually expect as support for a free component. Nevertheless I will help you once more. But actually I would be very glad if people would honor such service with a donation and do not take it for granted (as it sadly happens very often).
The color is defined in the default.css at line 143 where the rules for the html label tag are declared.
Good luck and Kind Regards,
11 years 10 months ago #984 by imkejoemrati
thank you aicha,
but the date fields still do not work
