getFieldAttributeArray not found
11 years 4 months ago - 11 years 4 months ago #1313 by ciecho
getFieldAttributeArray not found was created by ciecho
i just updated component on my site, and get error when open site where should be form:
#500 JHtmlVisforms::getFieldAttributeArray not found.
Please help me, what can i do ? previous version (3.1.2 i think...) works fine, but now how i can downgrade to previous version or fix that one?
update:
i just exported database, deleted visform 3.2.6, instaled 3.1.2 and upload database - it works (i have my forms and fields) but error still exist on new version.
Last edit: 11 years 4 months ago by ciecho. Reason: i found part of solution
11 years 4 months ago #1315 by Administrator AV
Replied by Administrator AV on topic getFieldAttributeArray not found
Hi Ciecho,
I'm sorry for your problems but there can always be a problem when you run an update, not matter how carefully I thave ested, because every Joomla! Website and every Visforms setup is different.
That is why you should always make a backup of your website before you run an update. That backup is your possibility to downgrade to the previous version!
So I'm glad to hear that you were able to go back to the previous version with the help of the exported database!!
I would like to find out, what goes wrong during the update on your website.
Can you please send me the exported database to contact@vis-solutions.de (or at least the part of it with the visforms tables).
There should be a file visforms_update.php in your logs folder.
Can you please send me this file, too.
Thanks,
11 years 4 months ago #1316 by Administrator AV
Hi Ciecho,
actually I just figured, that the error message you received, is not caused by problems during the update itself but because you have created an override for the visforms view in your template in the past?
I totally remodeled Visforms and the function getFieldAttributeArray, (which is used in the view) was relocated.
Visforms 3.2.x does not work with template overrides, which are made from previous Visforms versions default.php files.
So you have to remove the overrides and make new once from the new default.php files if you still need overrides.
The following user(s) said Thank You: ciecho
11 years 4 months ago #1349 by ciecho
Replied by ciecho on topic getFieldAttributeArray not found
Yes, You have right, i just checked logs, but it is not necessary now.
Thanks for help, i hope that information will be good lesson for others :)
Regards!
Ciecho
11 years 4 months ago #1352 by Administrator AV
Hi Ciecho,
I think you are not the only one who has created overrides.
So I'm quite sure, some people will be very happy to find this post!
And that is, what a forum is about, isn't it?
The following user(s) said Thank You: IreneLennings
