Urgent Help
10 years 9 months ago #1751 by aleyjendro
Urgent Help was created by aleyjendro
I'm using Joomla 3.3.3 and installed extension (Visforms for Joomla! 3 up to version 3.3.5 ).
Why i got 3 error messages such as :-
1 - Error Incorrect version sequence. Cannot upgrade 3.1.2 to 3.1.2
Warning
2 - Component Install: Custom install routine failure
Message
3 - Error installing component
Help Me :(
Thanks
10 years 9 months ago #1753 by Administrator AV
Replied by Administrator AV on topic Urgent Help
the messages say that you already have a Visforms 3.1.2 installation on your website.
It is not possible to install the same version twice.
10 years 9 months ago #1754 by aleyjendro
Replied by aleyjendro on topic Urgent Help
Already have a Visforms 3.1.2?
Before this, i already uninstalled and installed again, the message was appear.
What should i do??
Thanks
10 years 9 months ago #1755 by Administrator AV
If the message appears there is still an record set for the compent com_visorms in your #__extensions table, maybe in the #_assets table to. I don't konw why it is there. If something is messed up in your database you have to make sure that the previous installation of Visforms is completele removed
Check all folders in the installation
Export the database into a .sql file and search this file in a text editor for "visforms", to make sure, that no visforms record sets are in your database by accident.
