Submit button is not visible
9 years 11 months ago #2838 by Katerina Red
Submit button is not visible was created by Katerina Red
Hello!
Everything works great with the form except the buttons, submit or reset, none is visible.
I created the field but i don't see the buttons.
Am i doing something wrong maybe? Could you help me please?
Thank you in advance
9 years 11 months ago #2839 by Administrator AV
Replied by Administrator AV on topic Submit button is not visible
did you create a field of type submit in the form and no button is visible?
I've never heard of this.
Is the website online. Can you send me a screenshot of the button field configuration and a link to the form to contact@vi-solutions.de
9 years 11 months ago #2840 by Katerina Red
Replied by Katerina Red on topic Submit button is not visible
Hi, i sent you a screenshot of the button field configuration and a link via email.
Thank you!
9 years 11 months ago #2843 by Administrator AV
Hi Katerina,
thanks for the screenshot and the link.
Screenshot looks fine, so the buttons should be there, but obviously they are missing.
It is a bit difficult for me to understand everything I see on the website, because of the language.
Actually I think, that the template somehow removes the buttons from the form.
Could you please test with the Joomla! default template (protostar) if the buttons are missing there too.
If the buttons are visible with the protostar template this would indicate, that the problem comes from your template.
