Edit form - required and textarea
9 years 10 months ago - 9 years 10 months ago #2988 by Seth
Edit form - required and textarea was created by Seth
Hello,
please help me how can I change word Required to another word, and how can I change height and width on field textarea (its too big).
Thank you !
Last edit: 9 years 10 months ago by Seth.
9 years 10 months ago #2989 by Administrator AV
Replied by Administrator AV on topic Edit form - required and textarea
the text "required" comes from the language files. Did you look, whether there are translations available for your language? www.vi-solutions.de/en/documentations/visforms/translations
Those translations are made by volunteers. I do not check their quality.
You can use the language manager to translate the text if nothing else works. How to translate a text from a language file is a standard Joomla! technique which has nothing to do with Visforms. So please check the Joomla! documentation if you do not know how this is done.
Fields of type "textarea" have an option "Rows". You can set this option for example to "5". The textarea should be less high then.
