Visform Radio Buttons alignment
9 years 10 months ago #3000 by Louw
Visform Radio Buttons alignment was created by Louw
I'm sorry to bother you with this as I'm sure this is template specific but I have no idea how to fix it :(
I am using T3-framework template and your form and unfortunately I think something in the template is messing up the formatting. The radio buttons are not showing up correctly. I've tried to play around with advanced settings of Visform but no luck as then it displays the radio buttons as a list instead of inline.
Form layout is set as "default layout" and load bootstrap form css is set to yes
newnvdproperty.cloudaccess.host/index.php/en/contact
I would really appreciate your help with this as I'm completely at a loss.
Thanks
9 years 10 months ago #3003 by Administrator AV
Replied by Administrator AV on topic Visform Radio Buttons alignment
yes it is true, that some templates do not work together with Visforms as would be nice.
I could check into that. Most probably you need some custom css, but as this is individual support especially for your Website (Template, Contifuration...) I have to to charge for this. I offer a Support Ticket for this occasions which you could buy and which would cover my expense. I'm sure that I can figure a solution for your problem.
The Support Ticket description is in German, sorry for that.
9 years 10 months ago #3007 by Louw
Replied by Louw on topic Visform Radio Buttons alignment
I think it's not the fault of your extension as the T3-framework is terrible! Decided to use a different template on those pages to get around the issue. Thank you so much for your willingness to provide support. Understand completely that you have to charge for extra work.
Hope you have a great day and keep up the amazing work.
9 years 10 months ago #3008 by Administrator AV
you're welcome!
The following user(s) said Thank You: Louw
