Mobile and tablet view
9 years 9 months ago - 9 years 9 months ago #3090 by pokopikos
Mobile and tablet view was created by pokopikos
I created a horizontal form ----> 1 column with 5 fields.. But in tablet or mobile view i want 5 columns with 1 field (seperate the fields in new line) How can i fix it?
! There are bootstramp css files but i dont know in which line must edit....!
Last edit: 9 years 9 months ago by pokopikos.
9 years 9 months ago #3091 by Administrator AV
Replied by Administrator AV on topic Mobile and tablet view
this is the default behaviour of the bootstrap css.
If it does not work as expected this usually is, because your template is not a bootstrap 2.3.2 template, not a responsive bootstrap 2.3.2 template or has implemented other "breakpoints" (which control, when to show one row with 5 columns and when to show one column with 5 rows.)
You may ask your template developer how to fix it, that a bootstrap 2.3.2 multi column layout works properly with there template.
9 years 9 months ago #3093 by pokopikos
Replied by pokopikos on topic Mobile and tablet view
Bootstrap v3.3.2 is my template!!!
9 years 9 months ago #3094 by Administrator AV
sadly that is not Joomla! standard.
It is very sad, that many template developer do not respect the framework standards because therefore many third party extensions, like Visforms, which do respect the standard, do not work as expected (at least concerning the layout).
