Invio modulo
9 years 7 months ago #3095 by Eboli
Invio modulo was created by Eboli
I can not send the form: error :You can not find the page you requested. :( thanks for your help !
9 years 7 months ago #3096 by Administrator AV
Replied by Administrator AV on topic Invio modulo
after Update to Joomla! 3.5 you have to make sure that in the "Mail Options" in the form configuration the options
"Mail To", "Mail From Address" (for the result mail) and "Mail From Address" (for the recipient mail) are filled with a valid email address.
9 years 7 months ago #3097 by Eboli
Replied by Eboli on topic Invio modulo
the fields that you have shown me are already correct. but it does not work
9 years 7 months ago #3098 by Eboli
I tried them all! now I just have to uninstall visforms. Thanks anyway
9 years 7 months ago #3099 by Administrator AV
I'm sorry for your trouble,
Visforms is used by thousands of people and usually it works as expected and if there are problems I really try to help (mostly very successfully).
So maybe with a bit more information, we could have solved the problem.
9 years 7 months ago #3100 by Eboli
thank you; I set the form as indicated in your site, I can not understand why it does not work! with acy Mailing send properly. I can only send you the link to my site and see what it does. www.partipilo.it/partipilo click on the menu item: demo request. Regards, Bruno Eboli
