Problem with calendar and ReCaptcha
11 Jahre 11 Monate her #887 von stampgo7
Problem with calendar and ReCaptcha wurde erstellt von stampgo7
Hi there,
I have problem with the calendar. When you click on it does not open and the ReCaptcha does not refresh. This start huppens few days ago (for the past 6 months was ok. I notice that when I transfer my site in a new server which is in newer php. After that sometimes work ok but the most does not. Please help.
www.bookinginlefkada.com
Thank you.
11 Jahre 11 Monate her #889 von Administrator AV
Administrator AV antwortete auf Problem with calendar and ReCaptcha
I took a look at the link.
I found three different forms created with Visforms.
They do not use ReCaptcha but the Visforms Captcha.
Captcha refresh and calender works fine.
I tried from different system and with different browsers.
You say it sometimes works but mostly not.
The two things, the Captcha Refresh and the Calender, would indicate that is most probably a javascript problem.
So maybe it is a problem with your Browser?
I'm sorry that I cannot help you more at the moment, but without the error that is impossible.
Kind Regards,
11 Jahre 11 Monate her #890 von stampgo7
stampgo7 antwortete auf Problem with calendar and ReCaptcha
Hi and thank you for your quick replay.
You see it working well because that I already find out that the problem was from Simple image gallery pro. There are several options , so I found one which works together with vsform.
But what you mean ''They do not use ReCaptcha but the Visforms Captcha''? Should I deactivate joomla ReCaptcha plugin?
And to let you know more details about the problem, first time I notice that, the booking forms in hotels items were on right position. Then I decided to use {loadposition...} inside the articles (items because I use K2) and I noticed that when I changed position the calendar worked fine. After 2-3 days stopped working. All these changes in calendars operation were without do anything else, which is really strange. And then I sent you the first message.
If you know anything about all these, I'm looking forward to hear about.
Thanks again and I should submit that you have done grate job with vs form.
George.
11 Jahre 11 Monate her #892 von Administrator AV
Hi George,
thanks for posting this further information and your solution here!
It is sometimes difficult to understand all the interactions between different third party extensions and I do not have much knowledge about k2. What you describe is strange and sadly I have no explanation.
About the captchas. Visforms offers you different options. You can use the ReCaptchas or the so called visforms Captchas.
They look and work different. I just wanted so say, that you have enabled the visforms captchas and not the Recaptchas but that is quite fine. You do not have to change anything.
I think I wrote a bit more about the captchas in the documentation in the article about spam protection and captchas.
Kind Regards,
11 Jahre 11 Monate her #894 von stampgo7
Hi again
I can not find 2 option of Captchas. The version I use is visForms V1.0.0 and in the Advanced tap on each form there are the options bellow:
Use plugin Spambotcheck :
Use Captcha :
Captcha tips text:
Captcha custom error text:
Should I update or is something else?
George
11 Jahre 11 Monate her #895 von Administrator AV
that was the very first version which actually did have no recaptcha and did have the captcha options as you describe.
This version even doesn't support the Joomla! auto update feature which I implemented with Visforms 2.0.0.
I think you should consider updating to the most recent version. You find the downloads here:
www.vi-solutions.de/en/downloads-visforms
You would need the download of Visforms 2.1.1 if you are on Joomla! 2.5
There are lots of new features that came with Visforms 2.0.0 and with Visforms 2.1.0
And the documentation is for Visforms Versions greater or equal 2.0.0.
I strongly recommend that you make sure you have a full backup of your Joomla! Website before you run the update and that you test on a localhost if possible. Please have a look at the release notes of the downloads too.
Kind Regards,
