How to display two (or more) fields in one row?
11 Jahre 3 Monate her - 11 Jahre 3 Monate her #1651 von Administrator AV
Administrator AV antwortete auf How to display two (or more) fields in one row?
Hi Sam12,
I took a look at your form.
Sadly the template does not support the bootstrap 2.3.2 css as it comes with Joomla! and which uses the class attributes "row-fluid" and "span1, span2..." to create rows with up to 12 columns, as I described in the documentation.
The template is build on bootstrap 3.3, which uses different classes and is not compatible with the Joomla! 3.
Although the template developers have certainly done something to make their template work with Joomla! (I think they have written code that changes the class attributes create by Joomla!) the compatibility with third party extensions, like Visforms, is missing.
I'm sorry, but Visforms Layouts will not work very good on that template.
Kind Regards,
Letzte Änderung: 11 Jahre 3 Monate her von Administrator AV.
Folgende Benutzer bedankten sich: sam12
11 Jahre 3 Monate her #1652 von sam12
Thank you very much for the great job. I think I will use your forms for next project.
