How to display two (or more) fields in one row?
11 Jahre 4 Monate her #1623 von frederic@brettcom.com
frederic@brettcom.com antwortete auf How to display two (or more) fields in one row?
Great response, many thanks !
I'll try this quickly.
11 Jahre 4 Monate her #1624 von Administrator AV
Administrator AV antwortete auf How to display two (or more) fields in one row?
I forgot.
5) go in the administration to the module that displays the form and choose the defaultinline layout in the "Advanced" tab als "alternative Layout".
11 Jahre 4 Monate her #1625 von frederic@brettcom.com
Super ! Great ! :woohoo:
You can see the result at the end of this page : surycat.com/en/
Many many many thanks !
11 Jahre 4 Monate her #1626 von Administrator AV
Well done!
Kind Regards,
11 Jahre 3 Monate her - 11 Jahre 3 Monate her #1648 von sam12
Hi
Thanks for the great forms. I have a problem with two or more column in one row.
1- I used Visforms Version 3.5.0,
2- for first field I set up the "Options for multi column layout" width to 6
3- I did this for the second one. (I suppose they should be neighbor in a row)
4- In my Form at the advanced tab I changed the layout to "Multi column layout"
But unfortunately It's not working for me.
I use Joomla 3.4,1 Template Purity iii with T3
mmaiplaw.com/2/index.php?option=com_visf...orms&id=1&Itemid=105
Letzte Änderung: 11 Jahre 3 Monate her von sam12.
11 Jahre 3 Monate her #1650 von Administrator AV
Hi Sam12,
the steps you describe are correct. This would be the way to set up your form.
I was not able to check on the link, as you set the website offline.
Maybe you can mail me some login information to my contact@vi-solutions.de so that I can check on the form.
