Package Update: There was an error installing an extension: vfsubsfiles_j4.0.0_4
2 years 7 months ago #10045 by rusasadmins
I was able to install vfbase_j4.0.0_4.4.1.zip but get the subject error message when I attempt to install vfsubscription_j4.0.0_4.4.1.zip.
~ Steve
2 years 7 months ago #10046 by rusasadmins
Tried to install the subscription again and got the following error message.
Package Update: There was an error installing an extension: vfsubsfiles_j4.0.0_4.4.1.zip
2 years 7 months ago #10047 by rusasadmins
Components | Visforms | Dashboard
Warning: require_once(/mnt/data/vhosts/casite-1410831.cloudaccess.net/httpdocs/mm4/administrator/components/com_visforms/helpers/html/visformsselect.php): failed to open stream: No such file or directory in /mnt/data/vhosts/casite-1410831.cloudaccess.net/httpdocs/mm4/plugins/visforms/vfcustommailadr/vfcustommailadr.php on line 11
Fatal error: require_once(): Failed opening required '/mnt/data/vhosts/casite-1410831.cloudaccess.net/httpdocs/mm4/administrator/components/com_visforms/helpers/html/visformsselect.php' (include_path='.:/opt/alt/php74/usr/share/pear') in /mnt/data/vhosts/casite-1410831.cloudaccess.net/httpdocs/mm4/plugins/visforms/vfcustommailadr/vfcustommailadr.php on line 11
2 years 7 months ago #10048 by rusasadmins
Disabled all the Visforms plugins and was able to open the dashboard.
2 years 7 months ago #10049 by rusasadmins
But then when I try to install the subscription I get:
Joomla\Filesystem\File::copy: Copy failed.
2 years 7 months ago #10050 by rusasadmins
Visforms Base update successful
Please don't forget to update your Visforms Subscription to version 4.4.1. Older Visforms Subscription version are not compatible with this Visforms version and will probably break your forms.
and then ...
danger
Error installing package
