Übertragung bring Fehlermeldung
2 years 5 months ago - 2 years 5 months ago #10282 by prffrost
Replied by prffrost on topic Übertragung bring Fehlermeldung
Call Stack Meldung bekomme Ich nur wenn Ich das Template wechsel (Yootheme -> Cassiopeia)
Ich muss auch die Weiterleitungs-URL rausnehmen damit der Call Stack angezeigt wird.
Call Stack
#FunctionLocation1()
JROOT/components/com_visforms/layouts/visforms/success/messageblock.php:492include()
JROOT/libraries/src/Layout/FileLayout.php:1283Joomla\CMS\Layout\FileLayout->render()
JROOT/libraries/src/Layout/LayoutHelper.php:764Joomla\CMS\Layout\LayoutHelper::render()
JROOT/modules/mod_visforms/tmpl/default.php:685require()JROOT/modules/mod_visforms/mod_visforms.php:596include()
JROOT/libraries/src/Dispatcher/ModuleDispatcher.php:527Joomla\CMS\Dispatcher\ModuleDispatcher::Joomla\CMS\Dispatcher\{closure}()
JROOT/libraries/src/Dispatcher/ModuleDispatcher.php:558Joomla\CMS\Dispatcher\ModuleDispatcher->dispatch()
JROOT/libraries/src/Helper/ModuleHelper.php:2919Joomla\CMS\Helper\ModuleHelper::renderRawModule()
JROOT/libraries/src/Helper/ModuleHelper.php:16210Joomla\CMS\Helper\ModuleHelper::renderModule()
JROOT/templates/yootheme/packages/builder-joomla/elements/module/element.php:3411YOOtheme\Configuration\Resolver->YOOtheme\{closure()
JROOT/templates/yootheme/packages/builder/src/Builder.php:28112YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26713YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26714YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26715YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26716YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26717YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26718YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26719YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26720YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:26721YOOtheme\Builder->applyTransforms()
JROOT/templates/yootheme/packages/builder/src/Builder.php:10122YOOtheme\Builder->load()JROOT/templates/yootheme/packages/builder/src/Builder.php:12123YOOtheme\Builder->render()
JROOT/templates/yootheme/packages/builder-joomla/src/Listener/RenderBuilderPage.php 8524YOOtheme\Builder\Joomla\Listener\RenderBuilderPage->handle()
JROOT/templates/yootheme/packages/container/src/Container.php:26225YOOtheme\Container->call()
JROOT/templates/yootheme/packages/application/src/Application/EventLoader.php:5826YOOtheme\Application\EventLoader->YOOtheme\Application\{closure}()
JROOT/libraries/vendor/joomla/event/src/Dispatcher.php:45427Joomla\Event\Dispatcher->dispatch()
JROOT/components/com_content/src/View/Article/HtmlView.php:23728Joomla\Component\Content\Site\View\Article\HtmlView->display()
JROOT/libraries/src/MVC/Controller/BaseController.php:69729Joomla\CMS\MVC\Controller\BaseController->display()
JROOT/components/com_content/src/Controller/DisplayController.php:12230Joomla\Component\Content\Site\Controller\DisplayController>display()
JROOT/libraries/src/MVC/Controller/BaseController.php:73031Joomla\CMS\MVC\Controller\BaseController->execute()
JROOT/libraries/src/Dispatcher/ComponentDispatcher.php:14332Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch()
JROOT/components/com_content/src/Dispatcher/Dispatcher.php:5633Joomla\Component\Content\Site\Dispatcher\Dispatcher->dispatch()JROOT/libraries/src/Component/ComponentHelper.php:36134Joomla\CMS\Component\ComponentHelper::renderComponent()
JROOT/libraries/src/Application/SiteApplication.php:21835Joomla\CMS\Application\SiteApplication->dispatch()
JROOT/libraries/src/Application/SiteApplication.php:26136Joomla\CMS\Application\SiteApplication->doExecute()
JROOT/libraries/src/Application/CMSApplication.php:30637Joomla\CMS\Application\CMSApplication->execute()
JROOT/includes/app.php:5838require_once()
JROOT/index.php:32
Last edit: 2 years 5 months ago by prffrost.
2 years 5 months ago - 2 years 5 months ago #10286 by Administrator IV
Replied by Administrator IV on topic Übertragung bring Fehlermeldung
Hallo Wolfgang,
herzlichen Dank für den Call-Stack.
Issue [VF-1069] Forum: Bugfix 5.1.0 für Fehler in 5.0.1: Übertragung bring Fehlermeldung
Der Fehler tritt nur auf, wenn in der Formularkonfiguration auf dem Reiter Erweitert folgende Einstellungen vorgenommen sind:
- Erfolgsmeldung enthält einen Text.
- Es ist keine Redirekt-URL angegeben.
- Die Option: Auf vorherige Seite zurückkehren steht auf 'Ja'.
- Die Option: Formular mit Meldung ersetzen steht auf 'Ja'.
Nur dann kommt der Code in der Layout-Datei components/com_visforms/layouts/visforms/success/messageblock.php vorbei.
Es gibt einen Quick-Fix zur Behebung des Fehlers.
- vi-solutions.de/forum-bugfixes/messageblock.php_v5.0.1.txt
- messageblock.php
- components/com_visforms/layouts/visforms/success/messageblock.php
Last edit: 2 years 5 months ago by Administrator IV.
The following user(s) said Thank You: prffrost
2 years 5 months ago #10287 by prffrost
Wunderbar .. jetzt funktioniert es wieder!
1 year 5 months ago #11407 by Administrator IV
Hallo Wolfgang,
der Fehler ist bereits seit dem 16.04.2024 behoben und diese formale Meldung kommt nun zwar etwas spät, aber sie kommt.
Da war uns etwas durch die Lappen gerutscht.
Der Fehler ist behoben seit dem Release vom 16.04.2024 für Joomla 5:
Visforms 5.0.2
docs.joomla-5.visforms.vi-solutions.de/u...es/j5/version-5-0-2/
Visforms Subscription 5.0.2
docs.joomla-5.visforms.vi-solutions.de/u...5/sub-version-5-0-2/
