Urgent problem with Summary
6 years 10 months ago #6186 by Administrator AV
Replied by Administrator AV on topic Urgent problem with Summary
you can send the login to contact@vi-solutions.de
In the browser console on the source tab, you can see all javascript and css files. Sadly the media/com_visforms/js/visforms,js does not have a version (I should include that) so it is difficult for you to see whether it is a cached file (old version) or the correct new one.
Basically the files differ exactly in that line 688.
The code in the old file is
var fields = JSON.parse(visform.fields);
The code in the new file is
function createSummaryHtml(formid) {
and the line which would match the line 688 from the old file is now at line 690
var fields = visform.fields;
6 years 10 months ago #6187 by AndyG0HXT
Replied by AndyG0HXT on topic Urgent problem with Summary
Hi Aicha
Thanks for the update, I am using the old visforms.js file in that case. Do you have any idea where it might be stored on the MAC. I'm currently searching the entire disk for that file.
6 years 10 months ago - 6 years 10 months ago #6188 by Administrator AV
Sorry, no, I do not know where cached browser files are stored on MAC and how do clear them properly.
Last edit: 6 years 10 months ago by Administrator AV.
6 years 10 months ago #6189 by AndyG0HXT
Hi again
Solved, I found it and forcibly deleted the .js file.
Thanks for your help with this.
6 years 10 months ago #6190 by Administrator AV
You're welcome!
