invalid session token below sql statement
6 years 4 months ago #6440 by Administrator AV
Replied by Administrator AV on topic invalid session token below sql statement
And the css has to be
.visforms #ajax-modal-error-dialog.hide {display:none;}
6 years 3 months ago #6446 by Administrator AV
I just release visForms 3.13.8 and subscription 3.4.6 beta.
They contain a series of bugfixes and improvements especially with regards to the sql fields, which take into account your experience with those field types.
I fixed the "invalide session token" Error, which occured, if you use quotes (") in your sql statements (instead of sigle quotes (').
I added the bootstrap modal css, which is missing in your template and causes the ajax_error_div to show up, to the visforms css, too.
If you want to install the new releases, you have to download them manually from the downloads menu....
6 years 3 months ago #6447 by Tomy
Thank you Aicha,
Great Work!! I am having an awesome time using Visforms. Hopefully can complete my string of forms and utilize the plugin to the max!
Once again thank you.
Tom
